182 Trophy, Williams
				This is an intermittent fault which has existed for well over a year now.
Most times the car starts fine and runs great, however while driving the battery and stop light will occasionally flicker on for a second or two then go out.
Sometimes when trying to start the car it just won't turn over. The immobiliser light goes out when you turn the key to the ignition position as it should, there is a single audible click from the front left of the car, all of the other dash lights/clock go off as you turn the key to start, the engine does not crank, there is no repetitive clicking like you hear sometimes trying to start a car with low battery. If you push start the car, it fires fine and usually the next time you try to start it with the key it works, but then weeks pass and the problem happens again.
This problem existed both before and after the following items were replaced (possibly ruling them out?).
Starter motor.
Battery.
Alternator.
The battery and alternator are both brand new, Bosch and genuine Renault respectively, fitted by a well regarded Renaultsport specialist.
Several times before the car has gone back to specialist with starting fault, but because it is intermittent it's never acted up while with the specialist and is presumably therefore quite tricky for them to diagnose. Each time they've replaced the starter under warranty. I could push start the car and get it to the specialist, but then we'll be back to a new starter and the problem not occuring while at the specialist, only to happen again weeks later.
Anybody got any ideas? Thanks in advance.
Starter motor.
Battery.
Alternator.
