197/200 6 speed gearbox fitting into a 1*2 - works
Unless you're a mechanic or have ready access to all the equipment needed, it's gonna cost a lot for an extra cog. So I'd rather go the full hog have an R26 engine and box put in. £££
He's probably looking at using the 6 speed so he can get a dog engagement gear kit to fit inside the original 197 casing. Assuming they're available, which i'm 99.9% sure they are.
The 6 speed box does fit but you need to change the sump as stated.
Its a box that has closer ratios than the 5 speed and therfore better from competition...
Also you would think it would be more reliable.
My 182 box was just about to s**t itself before I sold it lol other than that it was fine. My 197 is a pita when cold. 1st gear is just impossible lol!
A friend of mine put a 197 motor + gearbox in 172 - car performs significantly better. if you can manage that upgrade its worth the hassle
if i was gonna go full engine and box swap and all that i would wait till better N/A engine mods come out for them before it gets put in so it saves on a lot more hassle :)
so does that mean a 197 gearbox will fit onto a 172 cup engine? and techinally it will go faster??
