197 intermittent starting issue
mad in general
  Clio 172 phase 2
Evening all,
A friend has a 57 plate 197. Owned since new.
When it was under warrantee Renault replaced the starter motor due to a fault. Recently when attempting to start he pops in the card, dips the clutch/brake and pushes the start button.
Sometimes the car starts first time no problem. Other times it either makes no cranking noise at all or it starts but there is a loud whining noise for a few seconds before it disappears.
Anyone able to shed some light on the most likely causes?
mad in general
  Clio 172 phase 2
Not without seeing it actually doing it, no
Cheers, up early I see.
Unfortunately seeing it is not possible, we are trying to fix this issue ourselves. Can easily swap parts over but fault finding is another story.
Any advice at all mate?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Yes, Live data is your friend... faults like this are nigh on impossible to fix without seeing whats happening (or not happening) as far as the ECU is concerned. Without it you will be guessing which gets expensive unless you're lucky.
