197 won’t start after gearbox change
Right troops! Needing some ideas here.
Just refurbed my box and put it all back together. Car now won’t turn over.
It’s key card/push start. I only get ignition when I push the button.
I’ve tested the starter, it’s fine. I’ve also checked it’s getting 12vs and it is.
MRBILLYUK
  FF Jeden Osiem Dwa
i've seen this problem mention on 1*2's . It was the earth strap from the gearbox not connected . Worth having a look at ?
  dan's cast offs.
Need 12v at the exciter wire when you hit the button. Checked battery is ok and check you've not missed any of the battery connections.
Also check the exciter wire is actually on the starter as well.
  renault clio 200
I had this problem also one of the wires to the starter I think it was the tiny one double check the wires to the starter if that take a get a jumper cable and earth it to the engine and body see if it starts if it starts it's a earth fault
