1999 Clio Alize 1.4 starting problem
Hi all,
I've recently been experiencing an intermittant problem when starting my 1999 Clio alize 1.4 8v. When I go to start my car, the engine just turns over but will not fire. The immobiliser seems to be working as it should and the light on the dash goes off when it should do.
After speaking to many people and having a look around on other forums,
I was led to believe the crank position sensor could be the problem.
I've now replaced the CPS along with the temperature sensor and the problem still persists!
After plugging in a 'AUTODIAGNOS MULTI TESTER PRO' diagnostics computer, the faults that are being brought up are as follows -
160- Actuator Relay Output Voltage
320- Injection-AC Connection
Can anyone shed a little light on what they may mean?
Any advice would be greatly appreciated.
Thanks,
Davie.
