any1 any idea wot power can be got out ov the 225 lump?
you baloon u knew wot i ment,, fred u got loom and ecu with that 2.0tany1 any idea wot power can be got out ov the 225 lump?
225 lol
I'm sure I heard some people saying they can be chipped and other bolt on parts for near 300bhp
How much do you have to spend? Its the laws of diminishing gains but realy pick you power or budget the box would get to its limit quick though its already there realy.any1 any idea wot power can be got out ov the 225 lump?
Custom shafts using 172 etc outers sleaved to megan inners.would u need to get drive shafts made up or dose the diff sit in same place?
Nope not directly you could dapter plate it but for simplicity plus the 5 speeds at its limits with 200NM so 300NM stock out of a 225 would kill it.would the 5 speed box from a clio not fit
Its not the same its all new realy just similar in some ways the whole engine built for turboing biger and stronger etc.If its the same bottom end, couldnt you simply slap the head on and all the other bits?
Infact how can it be the same bottom end? I cant imagine a clio running boost on standard internals lasting long. :S
Hi @Crusty this thread is years old.. start your own build thread.. Its been done lots of times now and Im sure you will get lots of help and advice. Welcome to CS
i swapped my master cylinder for a peugeot 406 v6 master cylinder as the fittings are on the other side and had new lines made to help stop my down pipe clashing search for 225 clio build youll see in there but cant help you with the gearbox issues tho
You need to speak to t.trophy (Steve)
Fairy Muff share your thread with others but come here when you get stuck
