2 down 2 to go! Refurb progress
Car  No more clio's for me!
Well, finally got two of the wheels finished now and i can finally see what their going to look like. I'm quite happy with how they've come out, there are a few areas which could have been done better, but hey its been done with spray cans from halfrauds! lol
Heres a few pics for ya :)
Not the best pics in the world! lol ;)
The other two need a bit work due to the kurb damage, but i've managed to fill (keeping the curve of the rim :D) and smooth down one alloy, heres a few before and afters. :)
Ta,
Dan :)
Cheers Matt, after using way too much paint and fcuking up the first one ten times, i've finally got the hang of it ;) lol
Nice one Dan . Looks like you've done a good job there mate . Alot cheaper than paying to have em refurbed eh ;) Did you use the metallic filler i mentioned , the Upol D Metallic Filler ?
I had something very similar in my stash. ;)
Works a treat and a piece of piss to sand down...which was very lucky in some cases! lol
Look fantastic, but you've painted the areas where the wheel nuts go. I did this on mine and the bolts kept coming loose due to the paint heating at a different rate to the metal (i assumed)! Took the paint off of that section and they were fine after that. Worth doing let me tell you!!!! :D
good to see your finally getting there dan.
if you fit them to your car and the missus nags you to get rid of your other set give us a ring, as i need a set ;)
No worries mate will do ;)
Just hope their careful with them putting them on, i can see me doing a lot of touch ups on the edges! :rolleyes:
I did this and almost lost a wheel mid-session at Goodwood.
Before you fit them you MUST remove the paint from the bolt hole where the wheel bolt seats...or the same might happen to you!
they look awesome mate!
will look the dogs once they're on the car! how much do you charge?!
Patrick_g46 said:
little bit of paitn remover then hose off, paint shud just flake off
Cheers mate, i'll make sure i'll get some sorted, don't want me wheels to fall off lol :)
dannyboy172 said:
Cheers mate.
60-90quid depending on materials and time ;)
that each or for a set of 4?!
do i get some courtesy wheels whilst your doing mine?!
Thats a set bud.
I will have a set of spare 172 alloys without tyres. Justin-172 is first in the que mind. ;)
