200 cup, vibrating noise around steering column over rough road surface...?
Car  RB Clio 200 Cup
Ok I know its French and I can take most rattles etc, but this one is getting annoying.
There seems to be a vibrating/buzzing noise around steering column when going over slightly rougher tarmac, only started recently. Sound like something is loose and then vibrates when the shock from rougher road surface makes contact. Doesn’t do it all the time but when it does it does my head in lol.
Any ideas of where it could be i.e. has anyone else had this and rectified it?
Thanks.
Have you tried re-adjusting the steering column? I.E. loosen it up, move it all the way down, up and then re-lock into your desired position?
No doesnt seem to happen when reving high.
Yeah tried adjusting the steering column as well.
Its probably something simple, but just wanted to ask if anyone else had it and resolved it.
