2000 1.9dti tuning capabilities.
Car  2001 CLIO 1.9 DIESEL
Hi Guys
I have a 2000 x plate clio 1.9 dti, that to be honest drives really well and goes ok for what it is. However i have done a little research and was looking at what tuning options there are if any and waht gains can be had.
A local place to me RS Tuning in leeds seem to know renaults and was going to enquire about a map, does anyone know of any gains this could have?
Also wondered about air filer,FMIC,turbo upgrade etc.
Sorry for all the questions, im not expecting a fire breathing animal but would like to have a bit of fun doing it and seeing what can or cant be achieved.
thanks in advance
Richard
Remap is usually the best option to get a good noticeable gain, obviously you wouldn't want to push it too far running standard equipment.
Personally I would get an updated panel filter or induction kit (which ever you prefere), update the exhaust system front to back and get it breathing nicely then get a remap. I don't know what the recommended BHP Is for your car on a standard clutch/ engine internals.... You may want more advice from someone that's more technically minded than myself!
Usually you'd get a FMIC when you turn up the boost / update the turbo .... Depends on how much money you want to throw at it!
I had a Fabia VRs that I mapped from 130bhp to 170, it was completely standard, had no problems with it however I found the clutch started to slip a bit. Apart from that it was fine, not only made a difference in torque and BHP but ran much smoother, was a completely different car to
Thank you for the reply pal. I dont want to really push the car as i do quite a lot of long distance mileage and it must remain bulletproof.
I am going to see a local place called RS Tuning that seem to know a lot about renaults. I dont expect a fast car but an improved drive and performance would be good. The car makes about 80bhp so i might look at a map / filter / exhaust and go from there.
Sounds like a plan! The beauty with turbos is that you can get nice little gains with the exhaust and filter alone, with a map too it should keep you happy!
You can usually expect to pay Upto about £300 for a map, £300 should get you a nice cat back and about 180 for a good induction kit.
Personally I wouldn't want to push your car over 120 bhp
Let us know what you get up to with it :D
