2002 172 brake pedal..?
Car  RenaultSport clio 172 mk2
Now then,
How do you dial out slack/float in the brake pedal?
Now I’m talking about mechanical travel.
Just fitted new brakes front and rear but there seems to be too much slack in the pedal before actual fluid pressure…!
Is it possible to get to pedal box and adjusted the excess movement out.
Any info would be gratefully received before I start digging.
sounds like you have not bled the brakes properly or you on about the small ammount of play they have?
Its the play i'm on about. i know from past frenchys eg citreons you can adjust the freeplay on them. Just wondered if you can do on the clio.
Actual pedal pressure is very good.
