205 45 Tyres on a 172 Cup - will they fit?
  Clio 172 Cup
Sorry if this has been covered before but I would like to run R888s on my 172 Cup which currently has 195/45/16's on the original Turinis but R888s aren't available in this size (nor are Kumhos or Yokos). Seems I have 2 options, buy a 2nd set of (15") rims & fit 195 50 15 R888s or stick with 16's & fit 205/45/16s but will they foul the arches or tramline or anything? The plan is to lower the car with Eibach Sportlines if that makes any difference? Cheers guys
I have 205/45/16 on my car now, look good and the little extra wideness gives a little rubber protection on the alloys, so less chance of curbing a wheel, there fairly cheap to, camskill and blackcircles do pirelli p zero neros for £70 each
  Clio 172 Cup
from what I've read 15"'s are a better solution anyway so looks like I'll have to find some more pennies to buy some F1s doesn't it!
  Clio 172 Cup; A3 3.2
sorry to steal the thread a bit, but what would be the difference in handling between the 15" and 16"?
i'm at the moment at the same point like you with my cup.
thx rgds robert
  Evo 8 MR
thx rgds robert
Tyres are cheaper for 15's. Also a bigger sidewall helps when cornering hard.
Gaz_
  Extreme mode
You sure about that fella?
Less sidewall, less flex......?
Anyway i always stuck with 195/45's. Cheaper, better imo. The 182 in lowspeed always 'chew' on heavy lock, over tyred imo
ripp
  182 FFAT
if lowered a bit it will look cool even with the 15's and the tyres will be cheaper(195/50) = win :D
