Sorry if these are dumb questions......
Is it best to screw the studs into the spacer or get longer studs and screw the stud through the spacer to the wheel hub ?
My concern is when screwed into the spacer it only goes in 10-12mm(?) which is alloy so might be a bit weak compared to the steel hub ?
If you screw the studs to the hubs then do you need to bolt the spacer to the hub ?
Which leads me on to which length stud do I need ?
Screw to spacer 60mm ?
Screw to hub 80mm ?
Are Rally design studs OK to use ?
BTW, I'm running the standard 172 wheels and want to retain the centre caps.
Screw to hub 80mm ?
