good bit of engineering work done by Craig (APD) therei was at the workshop on friday when you phoned about the timing.... looking at the 1st pic of the car you can see the flow to the rad is quite restricted with the cross member and oil cooler both covering it. is it possible to relocate the oil cooler to the left to free up some room ?
Removed the radiator about 30 mins ago, sending it back to Serck to see if they can make me a new one with an extra 3 inches on top. Will fit well and should provide quite a bit more cooling.
Carl
Drove the car back from Tour-De-Force this morning. Did 190 miles and averaged 36mpg
The car is running too warm so need to either get a new radiator or modify the current one as its not getting enough air.
Carl
bloody good result
so it must weight around 885kg's?
any more weight to save?
i got my 205 down to 800kg's now and with 200bhp or just a touch under i'm up around 250/tonne![]()
bloody good result
so your only 252/tonneso idential to my 205
this year it's been quite, as i had so much on, only done 3 track days, hoping to blag one this weekend too, but it's full, but hoping to drive there and hope someone dont turn up
that clio should be a blast now, got any planned track days?
