2nd hard drive power cable? (internal)
Car  mk2 172
hello,
im not really clued up on upgrading my pc but i decided to add a 750gb internal drive to my 320 one thats already there. took the case off and slotted her in, then plugged in the ribbon type cable. only to power it up then realise i couldnt find it on the pc. after much deliberation my only conclusion is that the cable thats on my existing drive that has 30v written on it is a power cable, and i dont have a spare flaoting around my case.
can someone please let me know how id go about powering this thing up?
cheers
ps if im totally off the mark i have only plugged one cable into the drive, its the larger of the two slots on the top half of the drive
SATA and IDE (ribbon cable type) are different.
You probably need a molex power connector and it sounds like you don't have any. In which case you just need a y splitter to give yourself another.
http://cgi.ebay.co.uk/4-pin-Molex-P...ryZ45342QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If your drive is SATA then you have the small SATA connector which transfers your data and then you need power. I don't know if it's the same with all drives but some will accept either a sata power connector or a molex.
