Ok, well im starting to loose patients with the clio now!
The high pressure power steering pipe broke (where it bolts onto the front of the gearbox,) in around Feb. This was replaced by renault for £700 quid. I then came to the conclusion that the reason for this was the engine mounts were f**cked. I then replaced them with k-tecs group N engine mounts to prevent the pipe from fracturing again.
Then in may/june time, the pipe broke again in exactly the same place. This was replaced by renault under warranty as the part was under a year old. I assumed it was just a faulty pipe which had been put on the car (after all, the pipe had been sat on the shelf for 5 years at renault, (date stamped on pipe)).
Today, i have noticed a small amount of fluid leaking, from once again the same point on the pipe. I will try and get some pictures, but where the pipe goes vertically infront of the gearbox, there is a square of metal welded onto the pipe so it can be mounted. The crack is happening just around the top of that square where it is welded on.
Please, if anyone has got any ideas, would be appreciated.
