30 Amp fuse - Causing engine to cut out!?
Car  Peugeot 308
Hello guys, got a Ph1 172 that's cut out twice in a week...
Basically it's a 30 Amp fuse located at the top of the engine fusebox!
As soon as I replace it, the car starts and runs again!?
Looks to be cutting the fuel pump off when it does blow??
Anyone had this? :dapprove:
IIRC f0xy had something similar, go to the point where the fuse was blowing when turning the ignition on. Turned out to be a faulty pump.
The 30 Amp fuse you describe is the one I removed when I replaced my fuel filter on my ph1 172 - part of the fuel pump system.
