he is using EBC though![]()
Which work fine...
I'm not going to even bother saying anymore.
Like I've said, I really cant be bothered. Speak to Tony about them.
'Fred knows best also...'
oh i agree 4pots are better, but still not a must, i never had fade issues in the Yoz monster and that thing didn't hang aboutPF97 pads, brembo discs, lines, fluid, if you get fade out of PF97 pads you need to look at your driving in my "knows best" opinion :rasp:
Is that s**t on your nose :rasp:!!!
Thats Fred's opinion, 4 pots will always be an 'upgrade' over a single piston calliper if not for overall performance then for heat dissipation. Everyone I have spoke to that 'really' drives there car has had fade issues. Most of CS need not apply.
Far from it. It's whats called sarcasm.
I agree there's benefits to 4 pots, I've never once said otherwise. Though IMO they're not worth the money (unless you're minted, then go all out!).
I can tell you now that I know more than a dozen people on CS that do trackdays/race who will say they have never had fade on standard calipers with aftermarket pads. That includes using EBC Bluestuffs(myself and Burpspeed use these for reference), even mediocre Ferrodo DS2500's! I can tell you also that we drive our cars hard and for long periods on track but most don't feel the need to come on here to say it, primarily because most of the time they'll be told they're 'wrong', by people who clearly are unable to drive smoothly / people that think they know better.
I think I've said enough, completely off topic as well. Apologies
Nick
"Most of CS need not apply" wasn't directed at you Nick or Burpspeed or Fred for that matter as I haven't seen videos of your track days but a lot of videos that I have seen and they comment "I get no fade" well there's a reason for that.
They are running good discs and pads and good cooling setup?
Most have been Brembo HC/DS2500/carbon lorraine combos and not sure on cooling tbh, probably fog lights out as most do but I'm not sure how much that does without the ducting and deflectors.
Fade or not has alot to do with how you brake as well .... those who race will spend enough time on the brakes and no more ..... fast road drivers and alot of trackday drivers spend way to long on the pedal. Fact !!
True.
Im guessing you ran compbrake/wilwood or the likes before Sam?
I have run willwood powerlites before ...wasnt impressed
True.
I ran Willwood Midlights and liked them the bleed nipples are shite though. I bought mine second hand and used standard discs.
4 pots didnt give me any more stopping power but made it easier to modulate the brakes and cheaper pads.
agree, but this is CS not billionaire boys club![]()
Have heard PF97's are 'the' pad of choice and do take a killing (pads do complete setup doesn't) and I have some to test when I get going, wont need 4 pots at knockhill as there's only one braking zone really In a slow little Clio although I am interested in good 4 pots that go under 15" wheels and don't cost a few limbs for when I go down south.
Anyway back on topic,
With the oz f1 in particular and with 15" rims in general on a Clio how much you space them out makes a big difference to what disks you can run due to the offset of the disk you are limited to.
I wanted to space mine 25mm anyway but have been forced to go to minimum of 30mm for brake clearance.
With 30mm spacers I've fitted a 24*300mm disk and a 6 pot caliper under the standard oz f1.
Been speaking to ap racing and that thickness of disks is something I want to stay away from, muchos money. Double the price of those linked calipers just doesn't make sense. The only way a homebrew kit would sell in good numbers would be using standard disks or scenic ones, too cheap to ignore.
