421's or 438's
Car  Ph1 T
Right I'm currently saving for the 438 cam package planned in getting it done in February but just seen a set of 421's come up for sale and wondering what there like?
Would I be better with the 438's or get the 421's
Whats the difference between the 2 and which will I get better gains/results from
Im running
OMP inox system with decat
Ktec induction kit (new style)
Dan
standard inlet, you'd be better off with 438s. With ITB's you wouldn't notice much, if any difference between the 2
I had Dan fit my 438's and a few other things. You wont regret it - the car feels fantastic now and pulls amazingly well. Idle is fine, better than standard cams actually. Also i have not noticed a drop in midrange performance at all.
How much could you do the cams supplied and fitted Dan?
Also, how much for Throttle boddies supplied and fitted ontop
Thanks Tom.
Thanks Tom.
That's 3 questions really, depends if you want cams a and remap package, then ITBs later, or all at once, or ITB's first, then Cams added later. All works a bit different each way, mainly down to the mapping
Prices are in my traders section
Dan I can't remember weather I've read that you use someone to map the cars or you do it yourself mate? Also I've already got the new ktec induction which goes well with the cams but what difference would the matched inlets make
Dan i would like a quote on throttleboddies cams and a map but your avatar tels me not to pm you.
Could you pm me or tell me how to contact you, i am very interested.
kit map I upload here and road test the car (eventually will be able to power run before and after)
Can organise custom mapping for some extra cost, this is not possible as a same day job though
