428 cams , will engine work properly whitout standart ECU re-map ?
Thats a name I havent heard for a while!
Presume you want to do this simply to get it to the place its being mapped?
If all you want to do is drive it on them to wherever is going to map it then you'll be fine. They run lean at the top end but not massively. Keep it under 5000RPM and 2/3 load and you'll have no problems.
Give me a shout if you want it mapping and you're in the South.
