4GB 800MHZ or 2GB 1066MHZ RAM?!
Car  2014 Focus Titanium
I have a budget of £60 for some RAM for my computer since mine just f00ked up. So, my set up is Q6600, Gigabyte P35-S3L Mob, 8800GT 512MB OC2 and I did have 2GB of 1066mhz ram with s**t timings (5-7-7-24).
Now should I go for:
4GB 4-4-4-12 800MHZ PC6400 RAM
or
2GB 5-5-5-15 1066MHZ PC8500 RAM
which would you go for and why? the advantage of the 800mhz is that i get 4gb straight away rather than in 6 months with the 1066 when i add an extra 2gb 1066. But however if in 6 months time i wish i had 4GB of 1066 i will have to rip the 800mhz out and buy 4GB 1066 rather than and extra 2GB.
Lol, help me decide!
I've got 4GB 1066Mhz, Vista 64 Bit, but talking from experience I'd go for 2GB 1066Mhz if I were you.
because you wont use 4gb !
my exchange box 170 users 2.32gb used memory out of 4gb physical and 4 gig virtual
my sql box 1.93 gig used
so a home machine unless your doing some huge 3d cad stuff you wont need it
RAM always helps especially with Vista, and since I use things like lightroom/photoshop/illustrator alot I'm sure the extra RAM would benefit me. But it's just how much with relevence to the loss in speed! :|
If your going to buy another 2gb in 6mths, it doesn't make sense to but anything other than the 1066 ram, you've already said that you only had 2gb before so you can work with that amount... : )
What you have to remember is while the bandwidth (MHZ) are increase the latency is too. There is virtually no real speed increase. The only reason for getting good memory is overclocking headroom thats why they typically sell at a higher price for the enthusiast market.
Even the very very high end memory is only around 5% faster than the cheap stuff you can buy so makes sod all difference in the real world. 4GB would be more useful and show you a larger increase right now. And it is easy to use 4gb in Vista.
2GB of decent 800, will easily overclock to 1066 if needs be.
Just not worth the extra moolah for minimal gains.
