96 clio bolt spacing
Car  1.2 clio
oi oi
im looking into lowering my clio and have found the kit i want but it comes in either 52mm or 54mm bolt spacing ive tried ringing renault and they are as helpfull as a bucket with a hole in th bottom,
does anyone know what the bolt spacing is or anywhere else i can find out
cheers in advance
antz
Renault don't know and since your not buying and since you can find out quicker than ringing a garage for certain whay should they try and explain this to you? Its just as quick to go and look yourself and you cna be sure.
get the wheel on full lock and measure the distance between the center of the two bolts holding the shocks to the hubs.
