If the phaser advances the inlet camshaft 16 degrees at 1450 rpm and retards it again at 6800 under control from the ECU, why haven't I heard anyone mentioning:
(a) that upper limit being moved up by the same amount when ECUs are rechipped and the rev limit is increased?
(b) that upper limit being put above the rev limiter maximum so you can go all the way to the rev limit without losing power?
