hi guys,
fitted new front brakes on my 182 o4 plate 1 week ago= no probs
fitted rear pads, discs bearing abs ring http://www.ebay.co.uk/itm/300857893832?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
and now all my dash lights come on stated in title...
i took brakes back off to find my right caliper no engaging onto the pad/disc as the nipple on the pad was in the way...
i fitted the pads so the nipple on both sides is on the outer side and the smooth side is touching the piston.
the lights come on whilst driving (not under braking)
im guesing the stuff i ordered may not be correct- meaning the abs ring is wrong?
i have looked about for other problems and found a guy mentioned(
Re: ABS SERV and ESP light.
^ issue is ecu see's brake fluid pressure but dont see pedal activity (as pedal swicth isnt activated yet) so thinks there is aproblem and deactivated abs + possibly esp.
often occurs after disc / pad replacement.
I found out hard way :s
now i have checked out this sensor/switch and all seems good to my knowelage.
im getting it jacked back up tomorrow and may just fit the old abs rings if this is simple enough.
any other suggestions would be really appreciated
thanks
thanks
