Abs Light???
Car  RenaultSport clio 172 mk1
Can any 1 help? every now n then, my abs & serv light come on in my clio 172 sport. Mostly when im on a poor road but sometimes for no reason. When they are on the abs doesnt work and when braking you can hear a ticjing noice by the footwell? any ideas??
cheers
Sounds like a loose connection. If it's to your abs computer then it shouldn't be too bad, if it's in your abs computer then you'll need a new one. A few hundred quid I think, I had one under warranty.
Cheers for that mate, where do i find the computer? and other things such as sensors so i can check them? would a diagnistic computer pick the fault up? thanks
get the driveshaft ring (target for the abs sensor) checked as can break causing intermittant loss of signal and may explain the noise as well
