Abs problem
Car  Clio
Hi all, I have a abs problem on a 2006 megane 1.6. The abs light has come on so I've hooked it up to the diagnostics and that's come back saying there's no reading from the drivers side abs sensor. Inspecting the sensor I found that the clip that holds the abs in had broke. Since then I've replaced the abs sensor and the wheel bearing as the sensor works off a magnetic ring inside the wheel bearing. The problem is that the light is still on and the same error keeps showing. Anyone had this problem? Any advice is appreciated
