ABS - Replacement / Bleed
Car  2005 Mondeo ST
Hi all
Managed to source a second hand ABS pump, what's the best method to replace / bleed system. I've heard that you need to prime pump first and jump the relays to turn pump on while bleeding
has anyone done one of these before? as I was just going to fit and do the two person bleed (one in car pumping brake pedal and another opening and closing nipple)
Thanks in advanced
