Abs ring
sbinks83@yahoo.Co. uk
Car  Clio 182 cup
I'm fitting new rear discs on my 182..I've removed the abs ring from the old disc,but it doesn't fit the new discs,it doesn't grip tight just spins like it's a mm to big.I'm using mtec discs,has anyone else encountered this problem?if so could you point me in the right direction of the ring I'd need?cheers
Don't deal with mtec @Darren S .
OE Renault or Brembo (if no abs) for the rear discs really due to the better bearings and abs rings fitted. If on a budget Mintex , wouldn't bother with anything else on the rear . Check the washer spacers are present and refitted
