Abs to non abs
Car  clio 172 ph1,golf v5
Hi , I am changing the brakes on my ph1 172 to the non abs cup set up and would like to know what does the arm on the brake compensation valve connect to? I think it is to the rear beam but not sure how it connects. Does anyone have any pics of one installed.
Dom
Haven't seen the. Valve your talking about. It I assume it's a load compensator
1 end is fixed to the car body and 1 to the axle the heavier the rear of the car is
it presses the rear end down opening the valve( think of it as a tap opened by weight in the car)
Before you bother the conversion I'd check the legality of abs removal for mot
The part doesnt connect to anything.
I fitted the cup set up to my 182.
I have detailed pictures in my project thread if you want to read
