Accelleration 'dips' when, err, accellerating..
Car  2004 1.5 DCi 80 Dyna
When I accellerate (MKII ph1) the power dips or 'falls out' for a brief second in all gears, once your cruising it seems to be fine but when you accellerating it drops out. Also at stationary it idles terribly, shakes the whole car like it wants to stall!!
Any ideas?
It does it at low revs. It doesn't always do it, it did it about 3 weeks ago for 2 days and has started again yesterday. could it be summet to do with the ICV?
The idle shake thing, could be engine mounts i guess. Do you see alot of movement if you leave it idling with the bonnet up?
Poor idle, inconsistant accleration, I really doubt that would be an exhaust problem.
Maybe a leaky vacum hose somewhere if theres no ECU lights?
Does it do it when hot and cold?
Does it only do it for the first 5 minutes ?
Due to the emissions thing on startup the ecu has a 'cold' program which makes the car a bit jumpy for the first few minutes.
When I say jumpy I mean it has a bit of a flat sport around 2500-3000rpm. During this period the rev limiter is also lowered.
Idle is slightly higher than normal during this period IIRC.
Any ideas?
Check the spark plugs??? Just an idea. Maybe air leak. Could be anything tbh. Need it testing properly by the sounds of things.
I will check it when I drive home tonight. The idling is very low and constantly moves up and down, it is not steady at all.
Oh and the car had a full service 2 weeks ago so the spark plugs are new and it has a new lambda sensor too.
Check MAP sensor and oxy (lambda) sensors... it's normally a mapping issue that's causing the hiccup
