BenR said:but both airbox feeds go to the front bumper area.......no hot air there.
7MAT said:OK I see what you are saying - but being an engine builder you must have a theory at least for why Renault added the valve in the first place?
wrx-172 said:Got to be there for a reason... If it doesnt do anything why bin it?
7MAT said:While I agree that the the 2nd air feed does not point towards the engine, it also does not feed down behind the bumper where the air is bound to be cooler?
In your professional opinion what does the valve do then and why was there never one fitted to the mki 172?
Neil G said:Nothing to do with air temp.
It's basically a device to alter the length of the inlets at different engine speeds to increase torque hence the two ducts.
If people want to cut pipes off and install air feeds to foglights etc and get the placebo effect of noise etc that's up to them....Renault took time designing the air intake system on the 172/182 to work well...I just don't see the point of messing about with it.
haitch said:binned mine this weekend, still very tight to get a 70mm caf in its place i thought.
GordonD said:Don't remove it. It improves low to mid range torque. Renault's engineers wouldn't have added the cost of it to the car if it didn't do anything.
What happens is that you get the best power at the top end if air can flow into the airbox with the least restriction. Ie, you want big air intake pipes. But if you have big intakes pipes at lower speeds when there's less air needed you get low air speeds. And when you factor in the pressure pulses that bounce back and forth in the intake system as the vales open and close you get flow reversals. The speeds up, stops, goes backwards, stops, goes forwards again. That produces less airflow that a smaller pipe that has a fast enough air speed in it that the pulses don't reverse the air flow. So what Renault engineers did was to have to pipes, both open at high speed for the least restriction, and one closed at low speeds for better torque.
Also if you open up that other pipe at lower speeds you get more noise. When they're on full throttle you don't mind noise. But when you're sitting on the motorway at lower revs and part throttle most grownups find intake drone tiresome. Closing the big pipe cuts the noise in those conditions.
The car will sound faster by making more noise if you remove the acoustic valve or lock it open. But it will actually be slower.
FredYozzasport said:anyway if you are a man and want a quick clio bin it!![]()
FredYozzasport said:4) its sh*t, bin it
