Adapt an autoleads adapter?
Car  Clio dci 80 2005
Is it possible to adapt a autoleads adapter to use the standard oem stalk to work my headunit.
Bought all the stuff a while back, unused, and upon raggin the dash to bits, it looks like the connections at the clock are different than the adapter i have.
Can only assume that the wiring was changed on the later mk2 ph2 models.
Is there any guides to which wire's to solder where, as im sure it would work, its just knowing what wires do what...
Cheers all
