Adjusting a non adjustable wastegate
Car  Clio 1.4 RT
My dad was complaining that his turbo didn't seem to be doing much and his car was generally slow and crap.
We checked the wastegate actuator and that was fully adjusted as high as possible (on the nuts on the rod that goes to the wastegate)
All I know about turbos is what I've read. Anyway I decided to unbolt the mounts to move the rod separately to see if maybe the wastegate was jammed open (bypassing turbo) as the car had been sat for 6 months previously.
It was fine but it was here I noticed that you could lift the actuator about another 10mm. I decided to stick a washer under the mounting plate to lift the actuator up and close the wastegate. took it for a run, slight improvement but still not great. Came back, added another washer lifting the whole unit up around 3mm. Now it runs perfect, acceleration is much better and the turbo still cuts out at the higher RPM.
I may have got some of the terms wrong here, I'm not a turbo mechanic just thought this may help someone.
However I will not be held responsible for any damage caused to your engine, run a boost gauge to make sure you're not gunna blow your rings or melt anything.
what about upping the fuel to compensate mate? or does your dads car do this automatically?
i dont think he would be very happy if it runs leans and blows
Diesels can't run rich or lean, they just make more or less power, any excess air or fuel just gets wasted. I did turn the pump timing up 1/4 turn anyway
