Aerial amp and boot light fuse, both dead! Wiring diagram?
Car  172 Cup
Strange one, got my multimeter out earlier as neither aerial base amp or boot light is working....it's measuring no voltage over either.
They're on the same loom too, which makes me believe they're connected somehow. Everything else on that loom (rear lights, number plate light etc) works fine!
So it's either a fuse or poor wiring.....
Anyone know what fuse it may be or if there's a wiring diagram showing them?
try f37/f6 10a fuse (UCH/multimer)in the main fuse box. I think it depends on if you have a ph1 or ph2 which one but I could be wrong.
Definitely not a fuse :-(
Pulled the boot switch out, and noticed one of the cables where snapped....bridges the loom but it still doesn't switch on :-(
Forgot to update: After messing around with snapped cables, rewiring, boot light is working now! Which tells me the loom is OK, and the amp in aerial base is fubard
