clio 172
Im tempted to remove the air con now is there any real point will i gain much weight reduction. Also which is the best kit to go for. Cheers
You can use some R5 parts to do it.
82 00 031 832 upper alternator mount
77 00 718 613 lower adjustable mount to tension the belt
77 03 101 094 long screw for alternator
http://www.cliosport.net/forum/showthread.php?685372-Air-con-removal-before-and-after-power-graphs
This is what I gained from removing the air-con, although Chip did strongly disagree with the results lol
Trying to source a cheap kit for my new engine.
you also need a smaller belt like a 5pk825, i think that was a R19 one.
Its much cheaper than buying a kit![]()
but why is a 172 cup significantly faster than a 172/182 with AC then?
It's worth it just to free up some space in the engine bay imo.
Aren't they lighter?but why is a 172 cup significantly faster than a 172/182 with AC then?
I'd consider doing it to save a little weight and free some space up if it was cheap but i dont fancy paying around 100 quid for it!
It can be done cheap, there's several cheaper ways to do it!
havent had air con in both my clios, can't say I miss it! Though I don't do many miles in it.
its not worth it. Your aren't going to get any driver noticeable gains, except for heat in the summer! Air-con compressors only really put strain on then engine when in-use, not when idle.
On the subject of removing air con system, what do people do with regards to the digital climate control, do they swap it over for a cup/ base model controller?
Removing air con:
Advantage:
Weight loss - yep, 20Kg
Possibly a small performance gain / less belt drag - very small
More engine bay space - why is this an advantage?
Cheaper aux / cam belt change costs - why? aux belt change will be about the same price, I don't see how the cam belt comes into play?
Disadvantage
Might get sweaty on a summer day - unlikely in our country, just open the window, but it is nice on the odd summers day
No 'fast' front window demister (I use this often).
Limited/no climate control
Just my thoughts on these points plus a few more added...
