Air con kaput
Car  Clio 182
Evening all,
Having some aircon woes-
Aircon isn't working, but the screen on the dash is.
I've replaced the resistor under the scuttle panel, tried 2 different units with no joy.
Done the test where you short pins 1&5 on the resistor plug, and it all fires up as it should.
What else could this be? I'm in the middle east so having aircon is an absolute necessity, otherwise its just a rolling sweat box
Many thanks
Mark
I reckon there's no gas in it. You can unplug the pressure sensor, bridge it whilst the aircon is switched on, and if suddenly the pump starts kicking in and out then that's your problem.
Fans are not working either
Surely if there was no gas in the system, then the fans would still work with the AC off?
I do know the system has a slow leak so there is also probably no gas left in the system - how do I go about bridging the pressure sensor?
