Air Filter - Clio 1.2 16v
you want to be careful with an oper filter like the px because if its put near the engine it will more than likely just suck in warm air which will actually cause you to loose power.
so id go for a closed ik like the viper.
do ktec do a ramcharger ik for a 1.2? i dont think they do thats wot i got on my 1.4 its closed and makes a wicked noise
u can get universal filters i believe so at a gues if u got a relocation pipe u could fir wot filter u liked on the end so long as it would fit the end of the pipe
right, time to clear this up
i had a pipercross vector filter fitted to the relocation pipe, that as removed, then replaced with a k&n for testing purposes (which fitted), that was removed very shortly after (crap filter) and replaced with an s-spec stainless filter, this also fitted the end of the relocation pipe
so from my experience all filters designed for the 1.2 16v will fit the end of the relovation pipe
Ali
  V6, Trackhawk, GTS
But which was best??? I got the one K-tec supply, the 1 that looks similar to a K&N...Are these Pants?
the filter i stuck with was the s-spec, got to say i never had any problems with it at all, to my knowledge fred is still running his s-spec, so again, musnt have had any complaints about quality from him
its a matter of personal choice, but IMHO the best filter was the s-spec
the s-spec is only available from halfords @ £99.99
it is made by pipercross specifically for halfords
And you would recommend this over other filters?
I ask because I have been looking into which one to get for my 1.2, along with a relocation kit.
