Airbag and EML light on - ideas?
Akay
Car  F54 Clubman S / Buzz
Hi all,
Bit of background - ph2 172, steering wheel airbag has been deactivated in CLIP previously.
Car has had a new battery and full dashboard out for EPAS conversion.
Also removed the engine wiring loom and cut back and removed aircon and pas wires to the fuseboard/ecu.
All back together and running OK, however Airbag, SERV and EML lights are on.
First question; do the EML/SERV lights come on with the airbag? I.e. potentially if I sort the airbag issue these other lights will go off?
The car has no MOT so I cant drive it to Mick @ Diamond, and im sure it will fail MOT with these lights.
Any simple checks for airbag issues?
Ok, thanks - I think its probably the carbon canister anyway.
Im going to take the dash top off tonight and check the connections otherwise im stumped!
