Airbag ECU Unlocking or Resetting?
Car  Clio 172 Ph2
Having 'Fun' with an accident damaged clio..... and 3 Airbag ECU's all locked.
Does anyone on here Unlock Airbag ECU's? so the VINs sill match?
I know I've had it done before.... just wanted to see if anyone on here did it.... keeping in the club.
I had mine done today however the car still will not run and the airbag light is still lit despite airbags being replaced.
Anyone from here had anything like this?
Check your seatbelt pre-tensioners mate. If they have gone off the airbag light will stay on. I've got a pair of fronts if you need them as well.
Pm me if your interested.
I don't think they've gone off, they're mounted by like a cable which I assumed would pull into the seat if they went off?
Sometimes even after the ecu has been reset you will need to go into in via diagnostics and turn it back on..... have you checked the inertia fuel pump switch?
