Airbag Help
Car  ATS CUP'd Dynamique
I am taking out the drivers seat of my clio, if i take out the seat the pretensioner and the airbag wont be there and the serv and airbag light will come on..
i have heard of this Diagnostic clip which renault can plug into the ecu and make the car computer think the airbag and prestensioner is not there and therefore no light will come on when i take out the seat
If this is true how much does it cost and where can i get it done
Think they can only remove the side airbags not the pretensioner too, costs about £25 I think for Reno to do it. I'd just use resistors, a damn sight cheaper and less faffing about.
i have read that, is it as simple as cutting the brown and orange wires and soldering a resistor to each end of the wires
Yes its that easy.. Ive done it didnt take long. What seats you getting. I got the ripspeed versions of cobra daytona. Oh and its worth paying the extra for the special sub frames the universal ones are s**t
under the drivers seat there are 2 clips : the black one is the pretensioner, i cut the brown and black wire and then solder a resistor to them.
the other clip is grey, on edde's guide it says to cut the brown and orange wire,but there are lots of wires going to it.. Lol
Im confused
kk thanks , the resistors need to be between 1.8-4 ohms
Im not an electronic whizz and dont have a clue where to buy them...where do you sugest
4 ohms is a better value to use others have had trouble with lower ones.
Maplins or any decient electrics replair shop will have them.
