Modified Clio 1.2
Ok, I have a Kenwood KAC 7252 amp, which is supposed to be powering 2 pioneer 306C subs. Now I took a crack at wiring it up today, but its not even coming on :S
I attempted to draw a diagram of how iv'e done it but my s**t pc wouldnt let me save it.
The Batt terminal on the amp: I have connected the thick blue power cable to this, and run it to the + of the car battery. ( Iv'e also instered a fuse in the fuseholder on this cable)
The GND terminal on the amp: I have connected the meter long clear cable to this, however I do not know where to put the other end of the cable, so it's currently touching metal.
P.Con terminal on the amp: I have connected the thin blue wire to this. This is then connected to a blue/white cable coming from the back of the head unit.
Then there is the Speaker Output terminals. I have matched these up with their pairs on the subs.
There is a Speaker Level Input slot, which iv'e insered the collection of black and gray wires which came with the amp, however I am unsure what to do with these :S
I have put the Line In cables into the Line In terminals on the amp, and the other end of this cable to the Line Out terminals on the head unit.
For some reason the amp is not coming on, does anyone know what might be the problem or what I have done wrong?
Thanks!!!
Thanks!!!
