amps
  clio 1.2 16v (facelift)
how can i run this amp at 2 ohms
4/3/2 channel/bridgeable power amplifier
80W x 4 (4 ohm stereo)
250W x 2 (4 ohm bridged)
12dB HP/LP fixed crossovers
Full range aux output
Dimensions: 13.75L x 10.875W x 2.25H
  RenaultSport Clio 172 Mk2
How would you wire them Dink?
In series from one channel through to another (but bridged) to show the amp 4 ohms, as you would voice coils on a sub?
ronny7787 - Don't think you can run the amp safely at 2 ohms to get more power out of it if that's what you're getting at? You'd need to buy a 2 ohm rated amp.
  Polo + Micra
you'd run them as 2 strereo pairs (4 speakers) one off each channel.
if you can bridge an amp into 4 ohms you can run it at 2 ohms(stereo) because bridging into is showing each channel half the load
