M
mij29
Well went to the garage today where i'd had my cambelt done two weeks ago and aux/belt came off 750miles later.
I told them about what reno/you lot have said about replacing the aux/belt with new if taken off to which they replied was aload of shite!
They hadn't fully striped the engine at that time so i went back later but before i went back i phoned Trading standards and told them the story. They said if i could prove that the belt had broke due to them removing ad refitting it then i had a case, She said they would have to do the work for nothing or at least offer some discount. Then qouted the 1982act of fair trading blah blah blah.
So i went back armed with this. When i got there he had done a search on the tinter net on cambelt changes and special precations and there was no mention of aux/belt change. He said i can see your pissed off so we will do the work at cost, so he has qouted me £450 for a
New cambelt kit
8 outlet valves (all inlet ok)
Head reworked
Head gasket kit
Aux/belt and pullys
Crank shaft.
Think thats it. What happend is the aux/belt came off/faild, wrapped around the bottom pull till it was so tight that it's bent the crank shaft throwing a piston out a few degrees and smashing two valves but he said he may as well replace all 8.
At £450 i doubt he is charging labour either. Still not good but i was expecting over a grand and they have lent me a car while the work is being done.
They have offered to do it at cost so i didn't bother mentioning The T/S .
New cambelt kit
Head reworked
Head gasket kit
Aux/belt and pullys
Crank shaft.
