another engine mount topic
i recently changed the dogbone mount,gearbox mount and the drivers side engine one.
trouble is even after all these when i'm driving along and let of the accelerator the gearsticks still shakes like mad.i had to drive for about 500 miles with a bent driveshaft which knackered the gearbox mount,so since all the mounts are now ok what could cause this?
i've heard the bent driveshaft could have knackered the gearbox bearings and this could be the cause?
when you press the accelerator hard their is no movement from the gearstick it's just when you let of the engine seems to be kicking back,i would just put up with it but with the amount of movement it will just ruin my new mounts.
i dont have the answer but my gearstick does the same thing and i replaced all of mine too! when i accelarate and let off.
