Clio II P2 172
Hi all!
Hoping for some suggestions on what to check out to narrow down my idle issue.
I recently picked up a P2 172 that’s done ~180k kms.
Since I’ve owned it it’s had a pretty rough idle, which I’ve heard is common on these cars but recently it’s gotten worse to the point where it stalls easily while reversing.
The car runs perfectly once it’s moving, but during idle it sounds like a boat. It doesn’t hunt, the needle stays steady, it won’t die while stopped and starts with no issues.
Previous to me owning the car, the belt & dephaser were replaced less than 10k kms ago, and I’ve been assured by the mechanic that did it that the timing is correct, was done by some French specialists here in SA. At the same time the coil pack, leads & plugs were inspected, but just the plugs replaced.
I’ve replaced the injectors because they’d never been replaced and we’re looking a little tired, this improved the way the car drives, but not the idle.
I have an RS tuner so once I’m home from work I’ll get some live data so that hopefully someone here can better diagnose.
What live information is needed to better identify an idle issue?
Any help you can offer would be hugely appreciated
So far I have;
So far I have;
- Lambda Sensor Voltage
- MAP Sensor reading
Once I’m home this evening I’ll post the results and like I said, hopefully someone more knowledgeable can help me diagnose. Cheers!
