Okay, heres one for you
What the part (connector) I need to buy for my mk1 172 setas to go into my mk2 ph2 car?!
And is it just a simple case of wiring?
Just get some normal connectors from maplins or similar. With the battery disconnected cut the blocks off and hook the cables up. Cant help with the colours cos mine is a mk2 ph1.
As for chopping bits of wire off etc be careful as the airbag circuits are heavily dependant upon resistance to check they are working properly. Dodgy connections/shortening or lengthening looms can cause the airbag control unit to flag a fault and bring up the light on the dash. Wherever possible i'd use the correct connections and try not to chop looms about.
