any difference in ph1 and ph2 sport brakes??
Struggler
Car  Ph1 track 172
im basically asking if these will fit a ph1 sport!
http://www.ebay.co.uk/itm/MINTEX-FR...&otn=5&po=LVI&ps=63&clkid=5071005050367858189
theyre listed up as for a ph2 172, but i didnt think there was any difference in the brake callipers so they should fit fine!!
i know many people do not rate these brakes, but im trying to stick to a budget and cannot stretch to Ds2500 just yet!!
im going to see how i rate these and possibly upgrade when it comes to it!
cheers!
thanks,
is there anything better you can suggest for the same kind of price range? (ie sub £80)
the car is mainly going to be a fast road with the occasional track day!! pads are going with brembo HC's
really though?? when running slick tyres or working the ABS, i would agree,
but im running road parads spec 2's and no abs!
also, ds2500 are not £30 more, theyre £55 more
even m1155's are £40 more, i already miss judge the price of pads in my budget as it is!! :(
Surprisingly tweeks were the cheapest for DS2500s for me last time I bought a set, do some ringing around and ask for the best price rather than relying on the advertised price. Sometimes you can get a bit knoecked off. In my case (18 months ago) they were £30 cheaper than everywhere else I tried, just by contacting their sales department directly.
Are you planning on going on track at all? If not just normal Pagid disks and pads is a great setup. £99 for both from me
I've tried the budget end of so-called "upgraded" pads and the mintex 1144's and ebc yellowstuff were both fine pads... but, seriously, no better at resisting fade than the O/E brembo's I chose this time. The wife has O/E pagid on her puma and they stand up to fairly heavy road use when I get to drive it too.
I would not recomend spending double O/E prices to get a SLIGHTLY better initial bite (cos that is the only difference I can tell). Stick to quality O/E stuff or buy propper performance pads, IMHO
Go for DS2500's I use them all round now my 172. They're worth the extra and last really well. Ideal for what your using the car for. Mine is the same,mostly fast road and a few trackdays. Also use DOT5 fluid for a better pedal and no fade when the fluid gets hot.
I have 1144s fitted, for the road they're ok for normal driving, I've gave them some greif with standard 182 wheels and they fade coupled up to HCs after 10-15 mins,
With my ozs fitted i've done the same they were fine i guess the standard wheels dont allow for much ventilation and help contain the heat! I only got them because they were on offer (£50), I wont be replacing them when the disks wear out though which wont be long they've pretty much paggered my disks over 2 year, Still have 60% on the pads!
I'l be fitting the DS2500s and new HCs next, Standard Renault is on the rear with Braided lines all round
