Ok next problem with the car... the clutch has been started creaking when you push the pedal up and down... its not the pedal assembly... and I can hear the noise coming from the fork on the gearbox... so it this likely to be the cable... the forks pivot or the fork on the back of the thrust bearing itself... has anyone else had this and found a fix? I dont want to start spraying wd40 down the boot around the fork and mess it up..
