Anyone got Wider Tyres on std Rims
Has anyone here put 205s on their std renault rims? The 195 tyres curve away from the rims inwards so would you be able to get the extra 10mm on?
Sorry, im talking abuot 172 renault factor fit wheels :)
Andy
Tom
  EV
TYRE SIZE
LOAD/SPEED
DIAMETER
WIDTH
RADIUS
REVS/MILE
ALT RIM
50 SERIES
195/50R15
82V
577
199
267
914
5.5 - 7.0
205/50R15
86 V
587
210
271
899
5.5 - 7.5MK1 Clio 172
Yes course you can..... I always put wider tyres on the front as companies set cars up for understeer and I hate understeer. Later I will post the address for the tyre size calc so you can see how much difference it makes to the size of the wheel etc. If you goto a good tyre fitting company ie dartford tyres they work it out for you
Cheers Steve
Any links would be appreciated, im in north essex so Dartford is about an hour away for me.
So does the extra grip at the front make it more balanced or now just cause the rear to seem more slidy?
  H22A7 Accord Type R
im hoping to shoe my dynamique wheels with 195/50 R15 rubber at my change! providing the alloys will take them............i think they should!
  Renault Laguna Coupe
Youd be better off lowering it if you want to reduce understeer Mav. Understeer isnt just a question of tyre size.
Well for me it enables me to keep more power on round corners and less understeer. But also it will make it just a little easier to get the back out, not much but enough to get you out some understeer sh*t and into oversteer fun... It just gives you better control of situations. Your find you be cornering faster :)
I will post link about 4.40ish
No your right there mike but you got to not just lower it you will have to get some coil overs and play with ride hight and damper settings.... tyres are a cheaper option to start with.. but I still think the tyres should be bigger on the front anyway
I would like to Mike but to do that i have to a) pay for the new springs (not much i no) and b) Direct line want an extra £258!!!!!!
No way!
So i think id go for the smaller tyres until i save up enough no claims. :(
wider tyres! lower profile... What are they standard on yours mav? if they are 195 50 16s Then 205 45 16s should fit no problem..... But if they are 195 50 15s then you might have a problem...... the bloke are darford will be able to help
Im OK, i have a MKII 172 so im on the 16s.
Ill have a look round for the 205 45s. If i can get them in eagles then ill go for if in January. Cheers Peeps
