Anyone had their coilovers set up at Demon Tweeks?
  S4 Avant
Yep.
The other week.
Charged £65
Wouldn't raise the rear (wheels sat in arches), saying that it would make the steering worse, set up camber and toe, told me I had worn track rod ends.
DrR
  VW Golf GTD
So they'll adjust my camber and everything?
What about ride height? Cos i have no idea if mines level.
  S4 Avant
They'll adjust all the camber and toe back to factory specs, but in my experience the guy wouldn't touch the ride height. Very odd.
DrR
  VW Golf GTD
hmmm might raise the fronts up on mine then, i'll have to put some pics up and let CS decide
The Boosh!
ClioSport Admin
  Elise, Duster
Rollo, check on alignmycar.com (or google it).
Will show you your nearest center. I used one in mansfield (not sure how close it is to you?)
Both the guys there are top lads. Use a hawkeye system which is mm perfect. Don't question what you want doing and advise you aswell.
I went to one place and asked for +/-2 deg camber and they said no way... The guys dont mind you getting stuck in either and explaining it to you... Cost me £45 for a full set up + a brew!. Would highly reccomend them. Chris (480bhp) gets all his cars set up there too..
Also Dave, I dont know why they told you your car would handle worse as mine was understeering quiet bad, but Chris advised me to raise the rear a couple of MM and the problem was solved. Very odd.
DMS
  A thirsty 172
I know Demon Tweeks aren't in Mansfield. I was replying to Boosh.
Who is it that doesn't like Mansfield then? Apart from me? There can't be that many who are fond of it...
Gaz_
  Extreme mode
Yep, had all three done there on the H&R's. Spot on!
Like the coils then? I thought they'd be too harsh for you being a welsh B road king tbh ;)
DrR
  VW Golf GTD
Think i do, well they'l do for now, seam good enough on the wem to whirchurch road, so i'm happy, not been to wales yet though.
