Apexi is a good plug n play for jap applications like already said. I used one on my old mr2 but i had to remove my air flow meter to use it. Good live mapping facilities and monitoring. Easy to use.
Doubt ud be able to plug it into a clio as easilly
Does GEN90 ecu's use only OE sensors or do you need to add or change any for a turbo setup?
Do they only work with MAF sensors rather than MAP's.
no they work for both types. I did have to change the map sensor though. think to a 3 bar one.
